Use the following procedure to edit queues of a queue profile, to configure a queue weight or enable rate limiting on the queue.
After you make the configuration changes, you must apply the queue profile before the changes take effect.
- Select Queue Profile.
Update a queue to configure
queue weight or rate limiting:
- Select the Queue tab.
- Edit AdminWeight and AdminRateLimitStatus by double-clicking on them, and then selecting or typing the new value.
- Select Apply.
Apply the queue profile for the
queue configuration to take effect:
- Select the Queue Profile tab.
- In Apply, double-click and select true.
- Select Apply.
- Select the Queue tab to verify updates to OperWeight and OperRateLimitStatus, for the respective queue.
Queue Field Descriptions
Use the data in the following table to use the Queue tab.
Field |
Description |
PId |
Displays the queue profile ID. |
Id |
Displays the queue ID. |
AdminWeight |
Configures the queue weight for weighted round robin (WRR), or the rate-limit in percentage of the link rate for queue shaping enabled on the queue. For rate-limit-enabled queues, 50 indicates 50% bandwidth. The overall rate-limit-enabled queues cannot sum higher than 100 min-weight. If rate-limiting is not enabled, this field configures the weight in the WRR scheduler. These values are not associated with bandwidth percentage. The following list identifies the default minimum weight for each queue:
OperWeight |
Displays the operational weight of the profile, described as a percentage. |
AdminRateLimitStatus |
Enables rate limiting on the queue. By default, rate limiting is enabled (true) for queues 6 and 7 only; it is disabled (false) for queues 0 through 5. |
OperRateLimitStatus |
Displays the operational status of the queue rate limit. |
